I figured it out. Next to where it says 'Health System Help' in the upper right hand corner, it shows the ID of the user logged in. If you scroll over that, it will show 'user preferences.' In this screen, click on the 'Event View Settings' tab. The second check box down is for 'Resolve all IP Addresses if Possible.' This is box that needs checked to resolve IP addresses in context explorer.
