URL Filtering not working though single url entry is working
amitkumarsi
Guys-
I have a SF 3D appliance which is managed by SF DC. I have installed URL filtering license using SF DC but URL filtering is not working. I put in single url entry e.g. www.yahoo.com in same access control policy and same is working.
Reading other pages I found this happens because of license issue. I re-checked licenses on SF DC and it's correctly installed and applied on my 3D appliance. I don't know how to verify licenses on 3D appliance itself to figure out what is causing this issue?
Please post if anyone of you have faced this issue?
Kevin P Sheahan
Level 5
Level 5
The issue is likely that the DC is not performing cloud lookups for 'unknown URLs'.
Go to System --> Local --> Configuration --> Cloud Services.
Ensure 'Query Cloud for Unknown URLs' is checked.
Kind Regards, Kevin Sheahan, CCIE # 41349
miculp
In addition to Kevin's comment, make sure the URL database is being downloaded properly. You can force that check in the same menu as "query unknown URLs"
