Using wildcard in URL filtering
lyutov_dv
hi,
How can i block all connections to *.microsoft.com (for example)?
Can i use custom URL object *.microsoft.com or firepower doesnt support wildcards?
2 Accepted Solutions
I remember not long ago opened a cisco tac with similar issue. and TAC advise to use a WSA. according to them FMC/Firepower sensor do not support wild card in URL filtering.
please do not forget to rate.
Sorry about that  - you are correct. I found a technote mentioning this as well:
https://www.cisco.com/c/en/us/support/docs/security/firesight-management-center/118852-technote-firesight-00.html#anc14
I tested on my FMC just now and found the same. However if I instead use microsoft.com instead of *.microsoft.com as my url object it works due to substring matching as described in the technote.
12 Replies 12
Marvin Rhoads
Firepower support wilcards in URL objects.
See the screenshot below taken from my FMC 6.2.2:
I can create an object but it doesn't work in access rules
Yes I found this technote...
it works but it's not the same because for example oldmicrosoft.com will be blocked as well, but it's another domain
Quite true - that is a limitation of the current platform.
I will remember to bring this up with the Cisco engineers at next week's Security team event.
So, what was the resolution to this?
We have a URL blacklist, with, as an example, 777.com in it.
777.com blocks, but www.777.com does not.
So, it appears the substring matching works if I create an actual URL object, then block it.
Substring matching, however, does not work, when populating a blacklist/whitelist in the Security Intelligence URL Lists and Feeds.
This document might be helpful FTD URL Filtering - How it works?
evan.chadwick1
what came of this.
IF Firepower can not process wildcard, why does the product allow them to be created. Surely its not that hard to detect a wildcard and not save it and put up a screen that advises so?
Rokib Hasan
Firepower does support wildcard, but not this format like  (*.microsoft.com) rather it support (.microsoft.com) format. You can create a URL object with value (.microsoft.com) for blocking all microsoft.com domain, it will block for support.microsoft.com/ www.update.microsoft.com/  or any other sub domain after .microsoft.com. So use dot(.) instead of asterisk(*) it will work fine. I am testing it in production environment.
bcoverstone
In FDM, all sub-websites match by just using the base domain name.
Therefore, just enter microsoft.com
Do not include an asterisk (i.e. *.microsoft.com)
Do not include a dot (i.e. .microsoft.com)
This will match microsoft.com, abc.microsoft.com, and abc.update.microsoft.com
However, notmicrosoft.com will not match
I have been testing this successfully. Here's the reference:
Cisco Firepower Threat Defense Configuration Guide for Firepower Device Manager, Version 6.2.3 - Objects [Cisco Firepower NGFW] - Cisco
Look under Configuring URL Objects and Groups
I'm using version 7.0.0.1 with FDM, I don't know if previous 6.x versions worked the same way.
