Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
1 milisecond timeout for ASA5550 failover
I get a 1 milisecond time out when a failover occurs. I feel this will affect connectivity for users. Should i be concerned
I have configured the following:
interface GigabitEthernet1/3
description LAN/STATE Failover Interface
speed 1000
duplex full
failover
failover lan unit Primary
failover lan interface Fail GigabitEthernet1/3
failover replication http
failover link Fail GigabitEthernet1/3
failover interface ip Fail 221.0.0.1 255.255.255.252 standby 221.0.0.2
failover
failover lan unit secondary
I dont have this problem when using Pix 525
Re: 1 milisecond timeout for ASA5550 failover
1 millisecond failover is more than you can hope on a network environment.
However, from your config i can see the stateful interface and the failover interface are identical.
This is something that Cisco advises against as during heavy traffic the stateful traffic information exchange might delay the failover messages, especially when using http replication. You should use different interfaces for failover and stateful traffic.
Daniel
Community Member
Hi I have tried different interface and the same thing occurs. I have this in a test lab and still get a time out with not network traffic running throught ??????? The config is only 129k
251
