106001: Inbound TCP connection denied from 172.32.1.101/49171 to 192.168.0.6/3128 flags SYN on interface outside
can someone please take a look at this and assist me ..
305005: No translation group found for tcp src outside:172.32.1.101/49171 dst inside:192.168.0.6/3128
config
PIX Version 6.3(1)
interface ethernet0 10baset
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
access-list 101 permit tcp any any eq https
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any host 192.168.0.6
access-list 101 permit udp any host 10.32.0.5 eq domain
ip address outside 172.32.1.1 255.255.255.0
ip address inside 10.3.0.3 255.255.0.0
global (outside) 2 interface
global (inside) 1 10.3.3.3
nat (outside) 1 172.32.1.0 255.255.255.0 outside 0 0
static (inside,outside) 10.32.0.5 10.32.0.5 netmask 255.255.255.255 0 0
static (inside,outside) 192.168.0.6 192.168.0.6 netmask 255.255.255.255 0 0
route inside 0.0.0.0 0.0.0.0 10.3.0.1 1
route inside 10.32.0.5 255.255.255.255 10.3.0.1 1
route inside 192.168.0.6 255.255.255.255 10.3.0.1 1
route inside 216.45.178.0 255.255.255.255 10.3.0.4 1
Bronze
Is there any particular reason why you have the following NAT rule:
If not, please remove that line. Also, make the access list 101 has a access group pointiong to the outside interface.
Juan Lombana
Please rate helpful posts.
Thank you so much for taking the time to look at this !
I removed the route and have a statement as recommended
Add the access-group : access-group 101 in interface outside
I still get the following errors
710005: UDP request discarded from 172.32.1.5/137 to outside:172.32.1.255/netbios-ns
106007: Deny inbound UDP from 172.32.1.105/63039 to 10.32.0.5/53 due to DNS Query
305005: No translation group found for tcp src outside:172.32.1.5/3474 dst inside:10.32.0.15/3128
Bronze
Well, on the last log you sent it looks like the destination is 10.32.0.15, based on the description you only have the following statics:
You can either add one for 10.32.0.15 or one for the entire network.
Juan Lombana
Thank you, any additional advise for the following:
Bronze
DNS server was probably too  slow to respond, and the query was answered by another server but those packets are not blocked by the PIX.
331
