2 different public ip address on ASA outside interface
My outside interface IP is blocked by ISP in one of the client locations , can I have them use the VPN client to send IKE request to a secondary IP on the outside interface (on the same ISP allocated LAN range).
I have ASA 5540 (8.0-3)
Hall of Fame Super Silver
An IPSec (or SSL for that matter) VPN can only be bound to an interface address - not to another address (on the same subnet or elsewhere).
Siju, it could be enabled to another ip address only if you'll change the interface ip address to the new address.
if the ASA on remote address is the spoke part, then you could had a redundant ip peers configured to spoke to the hub in the central office.
had a great day.
had a great day . best regards, and rate if you'll find this post useful
190
