2 PPPoE connection on ASA
is it possible to use, two interfaces with PPPoE connections. One interface for outgoing connections and the other one for a DMZ Server incoming connection.
Outgoing connections will use default route, incoming connections should be use a static mapping address.
Is this possible, any documantation for this case ?
Thx in advance and sorry for my bad english.
  • Firewalling
1 REPLY
Silver
Re: 2 PPPoE connection on ASA
Two PPPoE connections on same ASA can be done but PPPoE is not supported if you are using it for failover or redundancy.
172
