2921 Router configuration Secruity Zone help
I need help configuriong out 2921 router for a new DMZ area and Zones. I am new to the Cisco Configurator Professional and have setup most of what I can see but still does not work.
Need someone to complete the configuration. I do not expect this for free.
If anyone can help contact me at bsgjn@gmail.com, subject Router DMZ.
To start, here is what we need:
Configure one Cisco 2921 router for the following:
zones for WEB, Internal clients also with VOIP, a DMZ zone for our new Web server with an external IP address and one internal IP address
The Web server needs to have access to the internal data postgresql server only.
The DMZ connection will be through GE0/0 port on the router.
Internal network on GE0/1 to a layer 3 Cisco switch
Web on Fe0/0/0
VOIP on GE0/2
Thanks to all
  • Firewalling
Everyone's tags (3)
Hello Gary,
Can you post a diagram of your network and what you want to acomplish,
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Re: 2921 Router configuration Secruity Zone help
I need someone to do the actual configuration remotly
Basically he is what we need:
2 - ISP connections
1- Data and DMZ connection to Fe0/0/0
2- Voice WEB connection Gig0/2
1- DMZ area for a WEB server connected to gig0/0 (current settings no longer used)
2- Internal Voice and Data connected to router port gig0/1, that connects to Layer 3 switch with all the internal networks
Data goes toISP on fe0/0/0, voice to ISP on Gig0/2, DMZ to ISP on fe0/0/0
3- All Zones required
All VPN connections are authenticated with internal PDC
Gary Nicklaw
bsgjn1@gmail.com
Hello Gary,
Ok so it would be an innitial setup?
Julio
Yes
Purple
Hi garry,
your email address is not valid
Regards.
CADET Alain
Here you go
Gary Nicklaw
bsgjn1@gmail.com
Purple
Hi gary,
unfortunately I won't be able to help you till 04/02 because I must study for an exam so I won't have lot of time for helping.
Regards.
Alain
899
