Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
2x ASA 5510 -> Active/Standby Failover = 2x Licenses?
Hello everybody,
something is confusing me;
i red that you need only one L-ASA5510-SEC-PL for setting up a Active/Standby Failover.
I installed the license on the 1st ASA and tried to setup the failover via the ASDM wizard.
It always fails, because the 2nd device can't have a 'base' license.
So does this mean, i really need another license?
Thanks for the conclusion.
1 ACCEPTED SOLUTION
Red
Yes you would need another security plus license for the standby unit, just to enable failover license on it. The rest of the features on the ASA can be different on the two devices, as in number of contexts, VPN peers, annyconnect mobile. These things can be different on the two boxes. And this features is only available on post 8.3 versions.
In pre 8.3, you needed to have the exact same license and features on the two ASA's, which is not the case in your issue. Licensing can be a bit difficult to understand but you can get all the information regarding your setup in this doc:
http://packetpushers.net/cisco-asa-licensing-explained/
http://www.cisco.com/en/US/docs/security/asa/asa83/release/notes/asarn83.html#wp460665
Hope that helps.
Varun
Thanks, Varun Rao Security Team, Cisco TAC
Red
Yes, on both the ASA's you would need the exact same licenses, if you are using software version pre ASA 8.3, here are the failover requirements:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml
If you are using ASA version 8.3 or higher, then follow these requirements:
http://www.cisco.com/en/US/docs/security/asa/asa83/license_standalone/license_management/license.html#wp1455081
Hope that helps.
Varun
Community Member
Alright, but why do i get an error message then?
The devices are on 8.4.
And what is this sentence about->
"For the ASA 5505 and 5510 adaptive security appliances, both units require the Security Plus license; the Base license does not support failover, so you cannot enable failover on a standby unit that only has the Base license."
Red
The failover is disabled on the base license on ASA 5505 and ASA 5510, to enable failover capabilities on the device, you would need a security plus license, you can refer to the tables in this docs:
Varun
Community Member
Im sorry, but then it means i need another license right? i cannot share it? For me, this makes absolutely no sense.
Red
Hope that helps.
Varun
1607
