506e needs to be cycled repeatedly
I have a Pix 506e connected to the network. Symptom: If a PC user is not connected with their pc on when the server is rebooted then the Pix needs to be turned off and on for it to allow Internet access.
Is this a configuration error, failing hardware or something else altogether? Any advice is appreciated.
Re: 506e needs to be cycled repeatedly
rephrase please.
At the beginning of the work day the SBS is restarted. Everyone is okay. A salesman arrives from the field who was not around when the server was restarted. He turns on his laptop and connects to the network. He cannot connect to the Internet or the exchange. Through trial and error what seems to get him going is turning off the PIX and turning it back on. It interrupts users but is only the reliable way of getting them working.
Silver
Please past your config.
How many users do you have connected behind the pix?
Chad
If you are asking of the config.sys it is empty. There are about 20 local users and 11 connectng via a VPN.
Silver
If you have a TFTP server issue copy run tftp.
or
Issue sh run
Copy and paste config into text file. Don't forget to remove private info (ie passwords)
Chad
Bronze
Instead of rebooting...check the output of show xlate once he connects his laptop. There should be an entry with his ip address. Also try to ping some public ip like 4.2.2.2 and see the output of show xlate once again. If you get the ping reply then it could mean a Dns issue.
--Pls rate all useful posts--
Here is the config.
PIX Version 6.1(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname ETI-FW-01
domain-name et-inc.biz
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
name 192.168.10.9 ET-SERVER2
name 192.168.10.100 PIX-560e
name 216.37.30.0 SiteTechLLC
name 192.168.10.234 ET-SERVER1
access-list acl_out permit icmp any any
access-list acl_out permit tcp any any eq 1723
access-list acl_out permit gre any any
access-list acl_out permit tcp any any eq 443
access-list acl_out permit tcp any any eq www
access-list acl_out permit tcp SiteTechLLC 255.255.255.0 host 216.91.146.162 eq 3389
access-list acl_out permit tcp SiteTechLLC 255.255.255.0 host 216.91.146.163 eq 3389
access-list acl_out permit tcp any host 216.91.146.162 eq smtp
access-list acl_out permit ip any any
access-list 100 permit ip 192.168.10.0 255.255.255.0 192.168.1.0 255.255.255.0
no pager
logging on
logging timestamp
logging console debugging
logging buffered warnings
logging facility 23
logging queue 8192
interface ethernet0 10full
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside 216.91.146.190 255.255.255.224
ip address inside PIX-560e 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpngroup 192.168.1.1-192.168.1.25
pdm location 192.168.10.2 255.255.255.255 inside
pdm location PIX-560e 255.255.255.255 inside
pdm location 192.168.10.10 255.255.255.255 inside
pdm location 64.255.240.8 255.255.255.255 outside
pdm location 64.255.240.51 255.255.255.255 outside
pdm location 64.255.240.0 255.255.255.0 outside
pdm location ET-SERVER2 255.255.255.255 inside
pdm location SiteTechLLC 255.255.255.0 outside
pdm location ET-SERVER1 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 1 216.91.146.169-216.91.146.189 netmask 255.255.255.224
nat (inside) 0 access-list 100
nat (inside) 1 192.168.10.0 255.255.255.0 0 0
static (inside,outside) 216.91.146.163 ET-SERVER2 netmask 255.255.255.255 0 0
static (inside,outside) 216.91.146.162 ET-SERVER1 netmask 255.255.255.255 0 0
access-group acl_out in interface outside
route outside 0.0.0.0 0.0.0.0 216.91.146.161 1
timeout xlate 24:00:00
timeout conn 12:00:00 half-closed 1:00:00 udp 1:00:00 rpc 1:00:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 1:00:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 192.168.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community ETIpublic
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map etiremote 10 set transform-set myset
crypto map remote 10 ipsec-isakmp dynamic etiremote
crypto map remote interface outside
isakmp enable outside
isakmp key ******** address 216.91.146.190 netmask 255.255.255.255 no-xauth no-config-mode
isakmp identity address
isakmp keepalive 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup etiremote address-pool vpngroup
vpngroup etiremote wins-server 192.168.10.10
vpngroup etiremote default-domain eti-inc.biz
vpngroup etiremote idle-time 1800
vpngroup etiremote password ********
telnet 192.168.10.0 255.255.255.0 inside
telnet timeout 30
ssh 64.255.240.8 255.255.255.255 outside
ssh 64.255.240.51 255.255.255.255 outside
ssh 64.255.240.0 255.255.255.0 outside
ssh 192.168.10.0 255.255.255.0 inside
ssh timeout 5
terminal width 80
Cryptochecksum:ddcfaad4c7cd54879bce44878e655195
: end
[OK]
I just wanted to say thanks for the suggestions.
Sorry it took so long to respond I had a rootkit to kill. I will try the other suggestions and let everyone know how it works out. I would really like to scratch this off the list of to-do's. Thanks for the help.
104
