5505 help
need some assistance on setting up a asa 5505 at home...see setup below..
dsl -- asa -- wireless router
lets say my public ip is 70.158.1.10...i have my dsl set up as ip passthrough...the dsl also has dhcp turned on, the lan ip of the dsl is 192.168.1.254...on the interface e0 of the asa, im confused as to what ip to put...192.168.1.50? or an ip off the public ip?...now, on the wireless router, the lan ip address is 192.168.2.1...with this router, it looks for a WAN ip, you can statically put it in, or let it get it dynamically...i have tried puting the ip address of the asa to route it, but doesnt seem to work...
any assistance would greatly appriciated
my config below...
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.50 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 192.168.1.97 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 192.168.1.254 1
Re: 5505 help
You'll want to setup the DSL modem as a bridge or full IP pass-thru. The public IP is then assigned to your ASA outside interface. All your clients on the inside and your WAP will have a private address in the 192.168.2.0/24 range.
Re: 5505 help
ok, ill give this a try and update...
109
