Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
8.4 SNAT from Outside
Could anyone tell me why this statement does not work? (No real IPs useD) DMZ Interface is 10.0.0.1/24
nat (outside,dmz) source dynamic any  interface destination static OBJECT-01 OBJECT-01
object network OBJECT-01
host 10.0.0.2
nat (dmz,outside) static 1.1.1.1 dns
Also tested:
nat (outside,dmz) source dynamic any  interface destination static OBJECT-01-out OBJECT-01-in
object network OBJECT-01-out
host 1.1.1.1
host 10.0.0.2
It works fine as following:
nat (outside,dmz) source dynamic any PAT-DMZ destination static OBJECT-01-out OBJECT-01-in
host 10.0.0.254
host 1.1.1.1
host 10.0.0.2
Thank you
1 REPLY
1-Can you share the PAT-DMZ host
2- Why are you performing 2 different nats for the same purpose, I mean you are already letting the ASA now that if any outside users on the outside contact this ASA for the Ip address of Object-01 (1.1.1.1) the destination should be untranslated to 10.0.0.2 and the source should be translated to the PAT-DMZ ip.
So from my point of view you only need this:
With that line you are translating both the source and destination on one single line,
Let me know If I understood the question properly
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
306
