Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
A question about ASA 8.3 global ACLs against interface ACLs
Hello Cisco Experts,
I have a question about the Global ACLs feature introduced in ASA 8.3.
Which ACLs are match first, Global ACLs or the regular interface-base ACLs?
As I understood, if both Blobal and interface-base ACLs exist in the policy, the firewall will try to match (incoming/outgoing) traffic against the interface-base ACLs and if no match is found then the firewall tries  to match the traffic against the Blobal ACLs.
is that correct?
thank you
1 ACCEPTED SOLUTION
Re: A question about ASA 8.3 global ACLs against interface ACLs
It matches interface acl first before global.
Here is the documentation for your reference :
http://www.cisco.com/en/US/docs/security/asa/asa83/configuration/guide/access_rules.html#wp1083595
You can configure global access rules in  conjunction with interface access rules, in which case, the specific  interface access rules are always processed before the general global  access rules.
thanks a lot
10492
