able to ping from from inside interface but not outside
Users on vpn can not reach 1 particular host.
ICMP is allowed since they are able to ping other devices on our network when vpn'd in.
I am using ASDM to rung the ping test..
the first result is with the outside interface as source..the second is inside.
Sending 5, 100-byte ICMP Echos to 192.168.0.165, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 m
access-list a_splitTunnelAcl standard permit 172.20.0.0 255.255.0.0
access-list A_splitTunnelAcl standard permit 172.30.0.0 255.255.0.0
access-list A_splitTunnelAcl standard permit 192.168.0.0 255.255.0.0
access-list a_splitTunnelAcl standard permit 206.213.201.96 255.255.255.248
access-list A_splitTunnelAcl standard permit 206.213.207.96 255.255.255.248
access-list A_splitTunnelAcl standard permit host 64.14.47.15x
access-list A_splitTunnelAcl standard permit host 64.14.47.16x
route outside 0.0.0.0 0.0.0.0 64.14.47.190 1
route inside 64.14.4 255.255.255.255 172.30.0.1 1
route inside 64.14.4255.255.255.255 172.30.0.1 1
route inside 64.14.47 255.255.255.255 172.30.0.1 1
route inside 172.20.0.0 255.255.0.0 172.30.0.1 1
route inside 192.168.0.0 255.255.0.0 172.30.0.1 1
route inside 206.213.20255.255.255.248 172.30.0.1 1
route inside 206.213.2 255.255.255.248 172.30.0.1 1
172.30.0.1 is the interface on our network
172.30.0.2 is the inside interface of the firewal
Green
Re: able to ping from from inside interface but not outside
Can vpn users ping anything on 192.168.0.0? If not, 192.168.0.0 most likely needs a route to the vpn client subnet.
yes they can hit 192.168.9.6 for example
Does this device have two nics by any chance? Also, Check the routing table of the host "192.168.0.165" and make sure this host has a routing properly configured to route packets destined to the the VPN Pool of IP Addresses back to the client.
Also, what is this host? Is it a server or a VIP on a load balancer? Make sure that there are no filters that will block ICMP Traffic from the VPN Pool of IP Addresses.
Arul
*Pls rate if it helps*
110
