Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Access problem with Cisco ASA
Hi all, I m facing problem with ASA, here is scenario for the same,
I have 2 cisco ASA 5540 with multiple context.
Configured in active -active failover. My primary admin context is
working without any hassel. But when I tried to connect to outside
interface (secondary firewall)of admin contex it gives me an error
log - "ifc-classify --Virtual firewall classification failed."
From the same device if I connected from 'inside' - I am
able to. But not able to send any outside traffic. (Not able to
connect to gateway IP of outside interface.)
Please help.
Thanks in advance.
1 ACCEPTED SOLUTION
Re: Access problem with Cisco ASA
I would suggest you go thru this link (example 3) - Shared Resources for Multiple Contexts.
This example also has the nat/global config.
http://www.cisco.com/en/US/docs/security/asa/asa81/config/guide/examples.html#wp1009684
This happens when a packet arrived on a shared interface, but failed to classify to any specific context interface.
Use the global or static command to specify the IPv4 addresses that belong to each context interface.
Sorry, But I get this option. But dont know how configure global or static command.
Please, please help!
Still Unfortunate--
I tried to put static and global commands but no result.
could you share the sanitized config.
273
