Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Access Remote ASA usnig ASDM from HUB via Site to Site VPN...
HI,
I want to access my remote(spoke) ASA (ASDM) in my hub location..do not want to access via public IP from outside.
what configuration should be done on the spoke ASA..
                                               VPN Tunnel               SPOKE
      inside            HUB|=======================[ASA] inside 192.168.2.0/24
  192.168.1.0/24   ASA|
                                 |=======================[ASA] inside 192.168.3.0/24
                                            VPN Tunnel
2 ACCEPTED SOLUTIONS
Super Bronze
Provided that management connections are coming from a source address that is already configured on the L2L VPN and naturally that the destination address (Hub ASA interface IP) is also part of the current L2L VPN then you would essentially only need to add
management-access
Which would allow management connections through the L2L VPN to this internal interface
You would also need the appropriate statement to allow the ASDM management
http inside
I think you needed to use the "inside" at the end. Can't remember. Try "outside" if that doesnt work.
Naturally if you have any kind of VPN Filter ACLs or if you are preventing the default operation of VPN traffic bypassing external interface ACL then you will also have to allow the traffic.
Hope this helps
- Jouni
Super Bronze
Did you get it working?
Please do remember to mark a reply as the correct answer if it answered your question.
Or did you have the chance to test it out yet?
- Jouni
Super Bronze
management-access
http inside
Hope this helps
- Jouni
Thank you...Jouni
Super Bronze
- Jouni
Hi Jouni,
i have tested it on remoteaccess vpn and it is working fine. now only on site to site vpn i need to check.
suhas
402
