Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Access rule help on ASA 5520
Is this possible?
I have a ASA 5520 with a trunk to many DMZ's/VLAN's (Cisco 3750) and on one DMZ I have a server that needs to contact another DMZ's server but send on a particular UDP port but the server must recieve it on a different port?
For example it will send data on UDP port 8000 but the other server on the DMZ will recieve it on 8002?
Do I need to do a PAT?
1 REPLY
Re: Access rule help on ASA 5520
So both DMZ's are hanging off the same firewall interface with the ASA handing all the routing?
I believe you should be able to accomplish the port translation with a static statement.
114
