11-20-2013 12:43 PM - edited 03-11-2019 08:07 PM
We are implementing a program on mobile phones that access port 2439 for syncing files from a computer within the domain. I'm new to cisco routers, and am having a hard time wrapping my head around how to set this up. I'm using an ASA 5505 with ASDM 6.2. I'm just trying to use port forwarding to access the files. Any help would be appreciated.
11-20-2013 01:58 PM
Jeremy
Can you post current ASA config and remove any public IPs for secuirty.
Jon
11-20-2013 02:31 PM
I'm assuming this is what you are looking for.
ASA Version 8.2(3)
hostname ****-asa
domain-name default.domain.invalid
enable password encrypted
passwd encrypted
no names
name **.**.***.** Cox-Static-IP
name ***.***.*.* Site-*****-Subnet
name ***.***.*.* Site-**********-Subnet
name **.*.*.*** Video-Camera-DVR
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 10.0.0.100 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address **.**.***.** 255.255.255.240
interface Vlan5
no forward interface Vlan1
nameif dmz
security-level 50
ip address dhcp
boot system disk0:/asa823-k8.bin
ftp mode passive
clock timezone MST -7
dns domain-lookup outside
dns server-group DefaultDNS
name-server 68.105.28.16
name-server 68.105.29.16
name-server 8.8.8.8
object-group network MarvPc
object-group service 2439
service-object tcp source eq 2439
access-list outside_access_in extended permit ip any any
access-list outside_access_in remark Swann Security Camera TCP Admin Access
access-list outside_access_in extended permit tcp any host **.**.***.** eq 9000
access-list outside_access_in remark Swann Security Camera HTTP Access
access-list outside_access_in extended permit tcp any host **.**.***.** eq www
access-list outside_access_in extended permit tcp any host **.**.***.** eq 18004
access-list outside_access_in extended permit tcp any any eq 2439
access-list outside_1_cryptomap extended permit ip 10.0.0.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 10.0.0.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 10.0.0.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list outside_2_cryptomap extended permit ip 10.0.0.0 255.255.255.0 192.168.2.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-625-53.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 9000 10.0.0.125 9000 netmask 255.255.255.255
static (inside,outside) tcp interface www 10.0.0.125 www netmask 255.255.255.255
static (inside,outside) tcp interface 18004 10.0.0.125 18004 netmask 255.255.255.255
static (inside,outside) tcp interface 2439 10.0.0.110 2439 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 **.**.***.** 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication telnet console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 10.0.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer **.***.**.**
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 2 match address outside_2_cryptomap
crypto map outside_map 2 set peer **.***.**.***
crypto map outside_map 2 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 10
encryption des
hash sha
group 2
lifetime 86400
telnet 10.0.0.0 255.255.255.0 inside
telnet timeout 20
ssh timeout 5
console timeout 0
management-access inside
dhcpd dns **.***.**.** **.***.**.**
dhcpd auto_config outside
dhcpd address 10.0.0.131-10.0.0.150 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec
username aljoasatech password .fUia4yjsvpgYe4v encrypted privilege 15
tunnel-group **.***.**.** type ipsec-l2l
tunnel-group **.***.**.** ipsec-attributes
pre-shared-key *****
tunnel-group **.***.**.*** type ipsec-l2l
tunnel-group **.***.**.*** ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:b0c3b7b7db62ba5122feede6a72a65f8
: end
11-20-2013 02:58 PM
Your config looks fine assuming the internal machine is 10.0.0.110.
So is the port definitely TCP and are you sure there are no other ports needed for this connection ?
Jon
11-20-2013 05:46 PM
Well, I would change the next ACE due to security reasons:
enable
config t
no access-list outside_access_in extended permit tcp any any eq 2439
access-list outside_access_in extended permit tcp any interface outside eq 2439
But as Jon stated the connection should go through.
11-21-2013 10:06 AM
The computer I am trying to reach is 10.0.0.110, the server on the other hand is 10.0.0.115 Is there an issue with that? I just don't understand why this isn't working, maybe a setting I've overlooked? I have the ports open on 10.0.0.110 and a firewall exception on the server.
11-21-2013 11:50 AM
Jeremy
I'm not sure i understand. What is the difference between the computer 10.0.0.110 and the server 10.0.0.115. Which one are you trying to sync the phones with ?
Jon
11-21-2013 01:00 PM
If they are on the same subnet traffic does not even reach the ASA so I am bit confused on what you are asking
Value our effort and rate the assistance!
11-21-2013 01:16 PM
The mobile phones need to sync with a client computer @10.0.0.110. The server is 10.0.0.115. I added this info because the router seems to be set up properly yet I still cannot connect to sync the phones. I'm thinking I have something setup wrong somewhere, just not sure how to diagnose it. The phones sync fine while connected to the companies wifi using 10.0.0.110. But unreachable when I use the outside IP address. Sorry for being confusing, I was more trying to clarify the setup.
11-21-2013 01:20 PM
Jeremy
Still can't see anything wrong with your config. Is there a specific application name for the syncing of the phones ? It may be there is some issue with them using NAT.
Jon
11-21-2013 01:32 PM
It's a program called HandiFox, it's installed on the phones, and within quickbooks. It tracks inventory and sales. Supposedly it just needs port 2439 to be forwarded. They haven't had this problem before, is there any more info you guys would like to look at? Nic setting, firewall settings? My head is spinning like Linda Blair. It has to be a rookie mistake on my part somewhere.
11-22-2013 10:56 AM
After pooring over it a couple more times I realized Jumora mentioned the subnet. Finally noticed this in the log file
The subnet mask of that address is 255.255.255.0 Looks like this is the problem. Unfortunately I haven't found how to change the subnet of that forwarding. How can I correct this?
11-23-2013 07:21 PM
Oh my friend I believe that you are confused. Please call me juanmh84 through skype today or tomorrow or at my phone number that is posted on Monday after 11 am CST.
