Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Accessing DMZ webserver from inside using public IP
I have an ASA 5510 with a webserver in the dmz that is accessible to the outside from it's public IP (thanks to some help here yesterday), but not to the inside interface. I think I'm setting up the static NAT incorrectly.
The public IP is xx.xx.184.88 and the real IP is 172.16.0.176. I would like to use the public to view it from the inside interface. How would I configure that?
1 ACCEPTED SOLUTION
Green
Re: Accessing DMZ webserver from inside using public IP
Sure that would be fine. You should have something like...
static (inside,dmz) 10.39.239.0 10.39.239.0 netmask 255.255.255.0
Green
static (dmz,inside) xx.xx.184.88 172.16.0.176 netmask 255.255.255.255
or
static (dmz,inside) tcp xx.xx.184.88 www 172.16.0.176 www netmask 255.255.255.255
Hope it helps.
That moved the problem. Now I'm getting a "305006 partmap translation creation failed for tcp src inside:10.39.239.107/2198 dst dmz:xx.xx.184.88"
Should I post the config? Thanks!
Green
That fixed it, thanks!
137
