Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Acessing my ASDM....
I have the following...
----ISP provided router....192.168.1.1 set in bridge mode.....
----ASA 5510 outside interface set to ppoe
----ASA 5510 inside interface set to 192.168.10.1 (dhcp ips to other office pc)
----ASA 5510 mgmt interface set to 192.168.1.5
My PC is has the ASDM-ISM Launcher software installed on it...
IF I hook my pc to the ISP provided router I CAN access the ASDM.....but then I am not on the network so I can access the Internet or server........
IF I hook my pc to the inside interface I can't connect the ASDM.....is there some coding or something different I need to do to make this work??
Thanks!!
Thanks.
1 ACCEPTED SOLUTION
Re: Acessing my ASDM....
Make sure that you have something like this in your config:
http 192.168.10.0 255.255.255.0 inside
Also, make sure you are connecting to ASDM using 192.168.10.1 when you are on the inside network.
If that's still not working, you can check the output of 'debug http' to find out what might be causing the problem. This guide may also help:
https://supportforums.cisco.com/docs/DOC-13012
Hope that helps.
-Mike
Hope that helps.
-Mike
AWESOME!!!
Thank you Mike that fixed my problem......if they only was this easy!!!  Thanks again!!
Todd
274
