ACL doesn't match packets for NAT purpose
vdmbiny01
Hi, I cannot understand why ACL does't  match packets from PCs 192.168.8.2 or 192.168.8.3, but it matches 192.168.8.1(fa0/1).
In Wiresahrk I see source 192.168.8.2 when I run ping 192.168.176.58 from 192.168.8.2. However, it must be 213.70.2.2
By the way, I tried to set static NAT that worked fine, but it is not what I want.
interface FastEthernet0/0
 ip address 213.70.2.2 255.255.255.252
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.8.1 255.255.248.0
 ip nat inside
 duplex auto
 speed auto
ip nat pool pool1 213.70.2.2 213.70.2.2 netmask 255.255.255.252
ip nat inside source list 1 pool pool1 overload
access-list 1 permit 192.168.8.0 0.0.7.255 log
Router#ping 192.168.176.58 source 192.168.8.1
Router#sh ip nat tr
Pro Inside global      Inside local       Outside local      Outside global
icmp 213.70.2.2:4      192.168.8.1:4      192.168.176.58:4   192.168.176.58:4
Router#
Router#trace 192.168.176.58 source 192.168.8.1
Tracing the route to 192.168.176.58
  1 213.70.2.1 0 msec 0 msec 4 msec
  2 192.168.176.58 0 msec 0 msec 4 msec
Router#
chprocto
Try using a named standard access list instead.
Your example converted
ip nat inside source list nat-source pool pool1 overload
ip access-list standard nat-source
My output
icmp 213.70.2.2:24     192.168.8.2:24     213.70.2.1:24      213.70.2.1:24
icmp 213.70.2.2:25     192.168.9.1:25     213.70.2.1:25      213.70.2.1:25
Additional
if you only want to use the interface address, consider the following instead:
   ip nat inside source list nat-source interface fa0/0
thanks!
However, I managed to do this in this way:
ip nat pool pool213 213.70.2.2 213.70.2.2 prefix-length 30
ip nat inside source route-map isp1 pool pool213 overload
access-list 101 permit ip 192.168.8.0 0.0.0.255 any
route-map isp1 permit 10
 match ip address 101
 match interface FastEthernet0/0
It is pretty weird, but thanks god it works.
I do agree with Dasthomp, log keyword is not supported with nat acl, if you revert your original configuration back by removing the log keyword at the end of acl 1 you will be good to go.
Regards | Aref.
dasthomp
Last I check the use of the 'log' statement is not supported with NAT.
