For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
ACL issue with Router 2801
I have to implement an ACL on my router and have to block all the incoming access except some protocols.
Sample ACL is listed below
permit tcp any 29.165.175.0 0.0.0.255 eq 443
permit tcp any 29.165.175.0 0.0.0.255 eq 9000
permit icmp any any echo-reply
deny ip any any
The ACLs will be applied on “in” of the “outside interface”.
I just want to know whould it block the inbound request generated in return of the traffic which will be generated from inside, like if I browse cisco.com, would the request be blocked when the website contants try to come in from outside.
Do i have to use established statement or reflex access list.
Let me know please
Thanks in Advance
  • Firewalling
Re: ACL issue with Router 2801
Yes, return traffic will be blocked. I would suggest using inspect outbound in order to allow return traffic that is in response to an outbound connection (reflexive ACLs used to do it but they are deprecated now).
Here is a sample:
ip inspect name FW tcp
ip inspect name FW dns
ip inspect name FW
interface eth0/1
  description Outside
  ip inspect FW out
  ip access-group xxx in
I hope it helps.
PK
Thanks it make scence
if you are ok with it you can enable a bsic firewall
on the router thus making it stateful, this will work
use the following
ip inspect name fw dns
ip inspect name fw tcp
ip inspect name fw udp
ip inspect name fw icmp
and apply tihs on the outsid einterface in outbound
int fa0
ip inspect fw out
ip access-group 100 in
whr acl 100 wiull haev permt for out to in connections and deny for rest
this way you will make your router stateful and secure in to out return traffic is permitted
thanks its every helpful
What about Active and Passive FTP
inspect ftp but agian depends
where exactly your server is whether inside or outside
make sure the more specific one like dns,ftp,http etc come first then comes the more generic one's like tcp and udp
You can add
ip inspect name FW ftp
Please mark this as answered if it is, for the benefit of others.
PK
Just to be specific
ip inspect name FW          rule is for all the inbound traffic which is generated in response of the outbound access.
479
