Active/active failover in FWSM - silly question
Hello
I have two 6500 switches, each with a FWSM running OS version 3.1(4).
I configured active/standby failover, followed by active/active failover. The configs for both types of failover look very similar. The only additions for active/active seem to be
! context system
failover group 1
primary
admin-context admin
context admin
join-failover-group 1
context abc
Is this all? Results displayed by the "show failover" command also look very similar. There is nothing to indicate an active/active configuration or active/standby. Is there a simple way to be 100% sure what type of failover is configured?
Thank you,
Cristian
File with "show failover" results as attachment
jim
Re: Active/active failover in FWSM - silly question
You need to configure a second group which the secondary fwsm will be a primary.
#blade 1
Failover group 1
failover group 2
secondary
#blade 2
failover group 2
failover group 1
secondary
#sho failover
Failover On
Failover unit Secondary
Failover LAN Interface: FAILOVER Management0/0 (up) Unit Poll frequency 1 seconds, holdtime 15 seconds Interface Poll frequency 5 seconds, holdtime 25 seconds Interface Policy 1 Monitored Interfaces 3 of 250 maximum
Version: Ours 7.2(2), Mate 7.2(2)
Group 1 last failover at: 06:49:56 EST Jan 8 2007 Group 2 last failover at: 06:49:56 EST Jan 8 2007
This host: Secondary
Group 1 State: Active
Active time: 414641 (sec)
Group 2 State: Active
Active time: 70040 (sec)
slot 0: ASA5510 hw/sw rev (1.1/7.2(2)) status (Up Sys)
admin Interface outside (12.109.107.5): Normal
admin Interface inside (172.16.0.5): Normal
admin Interface DMZ (10.0.0.1): Normal
admin Interface management (172.16.255.51): Normal (Not-Monito
red)
slot 1: ASA-SSM-10 hw/sw rev (1.0/5.0(2)S152.0) status
(Up/Up)
IPS, 5.0(2)S152.0, Up
Other host: Primary
Group 1 State: Standby Ready
Active time: 0 (sec)
Group 2 State: Standby Ready
admin Interface outside (12.109.107.24): Normal
admin Interface inside (172.16.0.24): Normal
admin Interface DMZ (10.0.0.2): Normal
admin Interface management (0.0.0.0): Normal
(Not-Monitored)
slot 1: ASA-SSM-10 hw/sw rev (1.0/5.1(1)S205.0) status
(Up/Up)
IPS, 5.1(1)S205.0, Up
Stateful Failover Logical Update Statistics
Link : FAILOVER Management0/0 (up)
Stateful Obj xmit xerr rcv rerr
General 105117 0 62565 0
sys cmd 55988 0 55988 0
up time 0 0 0 0
RPC services 0 0 0 0
TCP conn 2725 0 6299 0
UDP conn 32 0 0 0
ARP tbl 46372 0 278 0
Xlate_Timeout 0 0 0 0
Logical Update Queue Information
Cur Max Total
Recv Q: 0 1 62565
Xmit Q: 0 1 105117
Thank you, Jim
So, the active/active configuration means that each firewall can be primary for one context, and secondary for another context. It's just an active/standby config, but the primary and secondary roles can be allocated to firewalls per context.
I expected a different behavior, the active/active designation seemed to indicate that both firewalls can process traffic for the same context at the same time.
Thank you,
Cristian
762
