ADSL Cisco 877 bridge mode and ASA5505
Good afternoon to everybody!
I have this scenario: Cisco877----------ASA5505---------LAN 192.168.2.0/24
I have configured my Cisco 877 in bridge mode. So my ASA5505 will have the public IP address on its outside ethernet interface.
Everything is working well.
But I have a question... Should I change the MTU for the outside ASAs ethernet interface? Now is set to MTU 1500.
For the "inside" is set to MTU 1500.
I have made a "show interfaces" at Cisco877:
Router#show interfaces
ATM0 is up, line protocol is up
  Hardware is MPC ATMSAR (with Alcatel ADSL Module)
  MTU 4470 bytes, sub MTU 4470, BW 734 Kbit/sec, DLY 500 usec,
     reliability 255/255, txload 22/255, rxload 77/255
  Encapsulation ATM, loopback not set
  Encapsulation(s): AAL5  AAL2, PVC mode
  10 maximum active VCs, 1024 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 362
  Queueing strategy: Per VC Queueing
  5 minute input rate 220000 bits/sec, 27 packets/sec
  5 minute output rate 64000 bits/sec, 28 packets/sec
     1669800 packets input, 1343751740 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 9 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1636733 packets output, 603190202 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
FastEthernet0 is up, line protocol is up
  Hardware is Fast Ethernet, address is
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 63000 bits/sec, 28 packets/sec
  5 minute output rate 215000 bits/sec, 28 packets/sec
     1621255 packets input, 586565449 bytes, 0 no buffer
     Received 37 broadcasts, 0 runts, 0 giants, 0 throttles
     1689219 packets output, 1328478895 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
FastEthernet1 is up, line protocol is down
  Auto-duplex, Auto-speed
     0 packets input, 0 bytes, 0 no buffer
     0 packets output, 0 bytes, 0 underruns
FastEthernet2 is up, line protocol is down
FastEthernet3 is up, line protocol is down
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is
  Last input 00:00:00, output never, output hang never
  5 minute input rate 75000 bits/sec, 29 packets/sec
  5 minute output rate 199000 bits/sec, 28 packets/sec
     1621764 packets input, 580695069 bytes, 0 no buffer
     Received 1600 broadcasts, 0 runts, 0 giants, 0 throttles
     1689302 packets output, 1321560584 bytes, 0 underruns
     0 output errors, 1 interface resets
Router#
Re: ADSL Cisco 877 bridge mode and ASA5505
hi ,
its my personal feeling, unless you are experiencing some issues and slow traffic, we should be ok with mtu of 1500 on the ASA
For now it is doing well.
It is just that I have read a lot of stuff from people saying that changing this parameter it is posible to surf the web faster. Because of no defragmentation of packets.
Let´s see what happens.
Thanks!
Sebastián Yáñez
Bronze
Hi Sebastian,
It is true that using a a lower MTU does help in certain scenarios.
But an MTU of 1500 is is used in most cases unless we have a VPN or some other service that encapsulates the packet (adds headers to the packet) increasing the packet size.
Anyway, try with a lower MTU if you are intersted and let me know your experience
Cheers,
Nash.
it depends on a lot of diffrent factors
  • vpn - ipsec usually takes something like 50 odd bytes of extra header and so you might want to reduce mtu so that it is fragmented in the first try and ensure correct packet delivery and reoder instead of retransmission due to fragmentation on the way, this way it helps in improving speed
  • also sometimes there are servers on which the mtu is hard set to something like 1300 or 1200 and in those cases we usually play around with mtu
but having said that, i have not seen many playing around with mtu unless there is an issue
if you want you can change mtu to 1400 which should be safe for most applications
1522
