Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Advice sought on freeing up memory on a PIX525 with 7.2(2)
If I need to reduce memory usage in a PIX525 running 7.2(2) what would be the first services to sacrifice? The default HTTP service inspection seems to offer very little but as most of our traffic is HTTP it is probably consuming some cpu/RAM.
I have three interfaces that each have an ACL of 1000+ elements. Do these consume a lot of RAM?
When I ran 7.1.2 the memory usage was 50% usually. Now it seems to be 70%. That said I have enabled multicast on the PIX - but the traffic volumes are very low.
Thanks.
Silver
Re: Advice sought on freeing up memory on a PIX525 with 7.2(2)
See that is why people are prefers Router / Switch for multicast.
You tells that PIX has too many ACL + Multicast and routeing must be there.
Natuarally CPU goes higher.
Suggesting you to put one perimeter switch and do multicasting from there.. One hop will be increase but better throughput you will get.
Now, If you would keep as it is.. few suggestion are here:
1) put MROUTE COMMAND for out going interface and remove unnecessary outside routes.
2) For access list watch carefully and if you can use WILDCARD Mask instead of indivisual ACL... that will help you to minimize entry of ACL. Less ACL less CPU/MEMORY utilization.
3)See hello timer default? by show pim traffic
You can maximize hello timer.
4) show igmp traffic , show conn .. monitor how much connection are there at atime.
5) capture trffic by using
ciscoasa#configure terminal
ciscoasa(config)#access-list captureacl permit ip any host 224.1.2.3
ciscoasa(config)#capture capout interface outside access-list captureacl
ciscoasa(config)#capture capin interface inside access-list captureacl
show capture capout
show capture capin
Monitor unecessary traffic from any HOT from ANY network.
Dharmesh Purohit
Gold
Everything i've read says that HTTP inspection does consume lots of resources, that's why it's disabled by default.
123
