After convertion to 8.4.2 code
Hi All,
I have converted an appliance from ASA 7.2 to 8.4.2
Everything is working but I was wondering if I can delete the following configuration lines in the code.
In 7 code we were using 'names' but now is everything refrenced to objects. Can we delete the 'names' without any problems.
regards,
Sander
1 ACCEPTED SOLUTION
Re: After convertion to 8.4.2 code
Hello Sander,
Yes, you can delete the names without any problems, it is not going to afect the configuration as the ASA is now using object groups for that.  Just place the no in front of the line and that should do it,
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
1 REPLY
Hello Sander,
Julio
167
