alias replacement to satisfy asdm
Hi there,
I am using alias command to give access to a server via it's public IP address (the dns server returns a private one). The syntax is:
alias (inside) 192.168.51.125 195.x.y.z 255.255.255.255
This works great. However asdm doesn't like alias command, there is something about bi-directional nat etc. I have tried to configure it but I failed, unfortunately don't have a chance to test it (they really need access to it almost all the time).
Any suggestions?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: alias replacement to satisfy asdm
I would recommend using the STATIC command here. The syntax would be:
static (inside,outside) 195.x.y.z 192.168.51.125 netmask 255.255.255.255.
If DNS points to your private address, this should work just fine.
379
