Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Allow HTTP POST
I have a cisco asa running 6.3
  I would like to allow HTTP POST method from specific IP range to a specific server.
all other IP addresses should only be allowed normal HTTP access to webserver.
   I tried to write up the policy map but getting a bit confused if the below if correct.
Please advice.
access-list POST_ACL extended permit tcp 10.10.10.0 255.255.248.0 172.16.0.1 eq 80
class-map POST_ACL
match access-list POST_ACL
class-map type inspect http match-all POST_METHOD
match request method post
policy-map type inspect http POST_POLICY_ACTION
parameters
class POST_METHOD
  drop-connection
policy-map POST_TRAFFIC
class
Everyone's tags (3)
1 REPLY
Community Member
Allow HTTP POST
I think if I change the access-list to deny that would rather work?
access-list POST_ACL extended deny tcp 10.10.10.0 255.255.248.0 172.16.0.1 eq 80
class-map POST_ACL
parameters
class POST_METHOD
  drop-connection
class
504
