allow ping to inside interface on asa5520
I have a access list to permet icmp any any, but, I still can not ping interface inside' IP address.
How can I configure the box to allow me ping inside interface?
Any comments wil be appreciated
Thanks in advance
1 ACCEPTED SOLUTION
Re: allow ping to inside interface on asa5520
you can never ..ever.. ping inside interface from outside the firewall or outside the DMZ if thats what you are trying to do...(possible only via VPN)
where are you trying to ping the inside interface of the FW..?
Hall of Fame Super Blue
Try adding the following in configuration mode
"icmp permit any inside"
Jon
Try this, in global config.
icmp permit any echo-reply inside
icmp permit any echo inside
icmp permit any time-exceeded inside
icmp permit any source-quench inside
456
