Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
allow port forwarding between port 100 to 1500 on ASA 5510?
Dear all,
I would like to allow port forwarding on ASA 5510 between port 100 to 1500, but i don't know which command that allow allow of port?
if only one port i can do like
static (inside,outside) tcp interface 25 192.168.1.13 25 netmask 255.255.255.255
but i want to allow start from port 100 to 1500( i mean that 100,101,102,1003----1498,1499,1500)
How can we do on thies?
Best Regards,
Rechard
Re: allow port forwarding between port 100 to 1500 on ASA 5510?
Port forwarding will allow to redirect a connection from one port to another (single port).
So, you can have multiple statements for multiple ports.
But if you're looking for a ''range'' option, there's no such thing.
You either redirect based on multiple entries (one for each port) or use another IP address that you can statically NAT.
Federico.
If you want to forward a whole range of ports from outside to inside,
upgrade the code to 8.3. In 8.3, you can forward a range of ports from
outside to inside.
object network test1
host 10.1.1.1
object network test2
host 100.1.1.1
object service ports
service tcp source range 100 1500
nat (inside,outside) source static test1 test2 service ports ports
Hope this helps.
NT
586
