Allow Traffic between subnets on ASA 5515x (9.1)
I'm Christopher and i am configuring an ASA 5515 with subnets across of subinterfaces (vlans). everything works fine, but are not subnets, ie no traffic between them. I hit the config for you to see if something is missing.
ASA Version 9.1(1)
hostname FWAISerena
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
ddns update method xxxxxxxx.no-ip.xxx
ddns both
interval maximum 0 0 1 0
interface GigabitEthernet0/0
nameif outside
security-level 0
ddns update hostname xxxxxxxx.no-ip.xxx
ddns update xxxxxxxx.no-ip.xxx
dhcp client update dns
ip address dhcp
interface GigabitEthernet0/1
no nameif
no security-level
no ip address
interface GigabitEthernet0/1.10
vlan 10
nameif inside_servidores
security-level 100
ip address 172.16.10.1 255.255.255.0
interface GigabitEthernet0/1.11
vlan 11
nameif inside_lan
security-level 100
ip address 172.16.11.1 255.255.255.0
interface GigabitEthernet0/1.12
vlan 12
nameif inside_wifiusuarios
security-level 100
ip address 172.16.12.1 255.255.255.0
interface GigabitEthernet0/1.13
vlan 13
nameif inside_wifipublico
security-level 100
ip address 172.16.13.1 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 100
ip address 10.200.200.1 255.255.255.0
boot system disk0:/asa911-smp-k8.bin
ftp mode passive
object network obj_servidores_any
subnet 0.0.0.0 0.0.0.0
object network obj_lan_any
object network obj_wifiusuarios_any
object network obj_wifipublico_any
access-list inside_servidores_access_in extended permit icmp any any
access-list inside_servidores_access_in extended permit ip 10.0.0.0 255.0.0.0 any
access-list inside_servidores_access_in extended permit ip 172.16.0.0 255.240.0.0 any
access-list inside_servidores_access_in extended permit ip 192.168.0.0 255.255.0.0 any
access-list inside_servidores_access_in extended permit ip 172.16.10.0 255.255.255.0 any
access-list inside_wifipublico_access_in extended permit icmp any any
access-list inside_wifipublico_access_in extended permit ip 10.0.0.0 255.0.0.0 any
access-list inside_wifipublico_access_in extended permit ip 172.16.0.0 255.240.0.0 any
access-list inside_wifipublico_access_in extended permit ip 192.168.0.0 255.255.0.0 any
access-list inside_wifipublico_access_in extended permit ip 172.16.13.0 255.255.255.0 any
access-list inside_wifiusuarios_access_in extended permit icmp any any
access-list inside_wifiusuarios_access_in extended permit ip 10.0.0.0 255.0.0.0 any
access-list inside_wifiusuarios_access_in extended permit ip 172.16.0.0 255.240.0.0 any
access-list inside_wifiusuarios_access_in extended permit ip 192.168.0.0 255.255.0.0 any
access-list inside_wifiusuarios_access_in extended permit ip 172.16.12.0 255.255.255.0 any
access-list outside_access_in extended permit icmp any any
access-list inside_lan_access_in extended permit icmp any any
access-list inside_lan_access_in extended permit ip 10.0.0.0 255.0.0.0 any
access-list inside_lan_access_in extended permit ip 172.16.0.0 255.240.0.0 any
access-list inside_lan_access_in extended permit ip 192.168.0.0 255.255.0.0 any
access-list inside_lan_access_in extended permit ip 172.16.11.0 255.255.255.0 any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside_servidores 1500
mtu inside_lan 1500
mtu inside_wifiusuarios 1500
mtu inside_wifipublico 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-711.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside_servidores,outside) dynamic interface
nat (inside_lan,outside) dynamic interface
nat (inside_wifiusuarios,outside) dynamic interface
nat (inside_wifipublico,outside) dynamic interface
access-group outside_access_in in interface outside
access-group inside_servidores_access_in in interface inside_servidores
access-group inside_lan_access_in in interface inside_lan
access-group inside_wifiusuarios_access_in in interface inside_wifiusuarios
access-group inside_wifipublico_access_in in interface inside_wifipublico
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authorization exec authentication-server
http server enable
http 172.16.10.0 255.255.255.0 inside_servidores
http 0.0.0.0 0.0.0.0 outside
http 10.200.200.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 190.98.204.80 255.255.255.248 outside
ssh 172.16.10.0 255.255.255.0 inside_servidores
ssh 10.200.200.0 255.255.255.0 management
ssh timeout 5
console timeout 0
dhcpd address 172.16.11.20-172.16.11.250 inside_lan
dhcpd dns 8.8.8.8 interface inside_lan
dhcpd enable inside_lan
dhcpd address 172.16.12.20-172.16.12.250 inside_wifiusuarios
dhcpd dns 8.8.8.8 interface inside_wifiusuarios
dhcpd enable inside_wifiusuarios
dhcpd address 172.16.13.20-172.16.13.250 inside_wifipublico
dhcpd dns 8.8.8.8 interface inside_wifipublico
dhcpd enable inside_wifipublico
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username cgutierrez password 9Aqxz2z4OgSesddB encrypted privilege 15
username admin password vAMrCPJV5P3jmuKo encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:4441640901d46fe224f7574fd2db08f9
: end
Super Bronze
Seems on quick glance that all your interfaces are set to "security-level 100"
To enable traffic between interfaces of equal "security-level" you will have to configure the following command
same-security-traffic permit inter-interface
Even if you have the interface ACLs configured to allow the traffic you will need the above command.
This is usually hard to troubleshoot with the ASA logs or even the "packet-tracer" test unless you know this sort of limitation exists.
Hope this helps
Let me know how it goes
- Jouni
I have got similar but not same on ASA 5505 firewall 9.1.
How can I just allow DMZ and Production on two ports for WiFi access point and seprate the traffic so DMZ traffic does not access Production network/subnet. Production network is Vlan1 and DMZ is Vlan 3 on ASA5505.
924
