Allow traffic inside to outside
One Host on inside network needs to access customized application hosted on Internet. Its a customized application run on port 80, 443, 5000-to-50020
How do I allow this host access for this specific application. I got ASA 5510 and host is in the inside network, we also got an ACL on inside interface to have control.
Host IP on inside network  - 172.16.30.15
Application to access - 74.219.x.x
Inside ACL name - inside-acl
cheers
Paul
Well, by default, all traffic from a higher security-level interface is allowed access to a lower-security level interface, unless there is a specific entry in an ACL that is blocking it.
If you have to include an entry in the "inside-acl" to get it out, I would do the following
object-group service CustApp tcp
port-object 80
port-object 443
port-object range 5000 50020
access-list inside-acl permit tcp host 172.16.30.15 74.219.0.0 255.255.0.0 object-group service CustApp
I think that's right. I sometimes have to use the ? mark to help me out, I'm winging this without an ASA handy.
Thanks John
what happens if the host access access public website www.yahoo.com ( port 80 ) ; will it be blocked
can i restrict bandwidth for this host to use 256kbps max for this connection (in/out)
cheers
Paul
The host should be able to acess the public website just fine, unless there are entries in your ACLs that are
preventing it from doing so. As far as restricting based on traffic, I'm sure you could do some sort of traffic polcing
or QoS for that specific host, but I have no idea how. I've never done that on an ASA before, so I don't want to tell
you wrong.
Hi John
I want internal host 172.16.30.15 to talk to external host 74.219.x.x on port 80, 443,5000 50020 only.  Traffic initiated from host 172.16.30.15 to any other host on internet should be blocked.
cheers
Paul
I would apply this to the inside interface. Now, I have no idea what specific entries you have on
your inside access list, so I'll write it, as if it's a brand new configuration.
access-list inside_access_in permit tcp host 172.16.30.15 74.219.0.0 255.255.0.0 obect-group service Ports
access-list inside_access_in deny ip host 172.16.30.15 any
access-list inside_access_in permit ip any any
access-group inside_access_in in interface inside
This will allow host 172.16.30.15 tcp access to 74.219.x.x on the specific ports, then all other IP traffic
will be denied via the next line. Then you will have a permit ip any any at the end. That way everything else
is wide open outbound.
337
