Allowing connection from hosts to outside local network via remote gateway
today I got a call that one of our employees needs access to a remote machine from his work PC, which wouldn't be a problem, but the remote machine has a private IP address (10.10.x.x) so a person from that company gave me the IP of a remote gateway I have to use and I can't get it to work. I need to know if I'm missing some information from their side or if my configuration is wrong. This is on 8.2 by the way.
On the WAN interface I added an ACL that allows the remote gateway to access the NAT-IP of the network via port 3389 and 3391.
access-list internet_access_in line 1 extended permit object-group DM_INLINE_SERVICE_9 host remotegw host privatenat
The private network on our side already has an ACL that allows access.
I tested the traffic bi-directionally (src. remotegw to dst. privatenat via 3389 and src. privatenetwork to dst. remotegw via 3389) and packet tracer shows me that the packet is allowed, but I can't connect.
Is there something I'm missing when it comes to the firewall configuration or would you say that the problem lies elsewhere?
Thank you
1 REPLY
Can you share the
Can you share the configuration from the ASA device and IP address information description ?
Thanks and Regards,
Vibhor Amrodia
30
