Allowing Ping from LAN
I have a new 5505. My ping(icmp) requests are getting dropped from both the 5505 as well as the LAN its connected .
How to enable the icmp ??
Re: Allowing Ping from LAN
Hi ,
Try the below config on ASA will help ur issue.
I assume here for testing i put any for source & destination is inside interface IP.
Try to create acl with inside_test like below & put u r inside interface ip @ end.
ciscoasa(config)#access-list inside_test permit icmp any host 192.168.1.1
Apply the ACL in Inside interface & then try
ciscoasa(config)#access-group inside_test in interface inside
Ritesh Malviya
Now I can ping the internal Interface of the Firewall but not beyond that. From ASA too i'am unable to ping domain or IPs in internet.
Sastry
If possible then pls paste running ACL part on u r ASA .
Ritesh Malviya
142
