Allowing PPTP connection through a Cisco 877 ADSL Router
I have just setup my first Cisco ADSL router, I have decided to setup the firewall with the Zone wizard. This is for a guest network and everything works fine except guest users are unable to connect to external to their remote sites via a Microsoft PPTP VPN.
Cisco Any Connect works fine but that uses different ports, I have added both these commands but it still doesn't work.
access-list 100 permit gre any any
access-list 100 permit tcp any any eq 1723
I think there may be an issue with gre inbound but I am not sure, I was wondering if anybody could have a look at the config (External IP's and passwords removed) and see if I am doing anything daft?
If you need any more information let me know, thanks in advance for any assistance on this!
David
Building configuration...
Current configuration : 8342 bytes
! Last configuration change at 09:18:02 UTC Fri Sep 13 2013 by *
version 15.1
no service pad
service password-encryption
hostname EDI-ADSL
boot-start-marker
boot-end-marker
no logging buffered
enable secret 4 63Lst2Pnk31pT7MbMMfjPdBjH38eoq7hvuC.FrOsSvI
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-1182812878
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1182812878
revocation-check none
rsakeypair TP-self-signed-1182812878
crypto pki certificate chain TP-self-signed-1182812878
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31313832 38313238 3738301E 170D3133 30393131 31343337
  33315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 31383238
  31323837 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100DA35 CC5DFFB8 91390002 86C033E7 811D4FE3 E3DF9020 50A41D7F 7DE64395
  5F627432 683D4D9E 1625C4EC 1EE90A24 E166A011 837CE613 4ED092B6 B2FA9F71
  543009A5 E5DCE7D6 ACB0DDD8 E49CDFA3 21E127A8 0ED961EC F1279C08 0635D0DF
  3FDC73D7 1A5F1704 EE9250C2 B66747EF 86CEB3AE 28669F1B 6E80B8FB 4155AABC
  8CEF0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14A371E0 4CF9EE5E ABA8466F DFEBC167 725B6F42 0C301D06
  03551D0E 04160414 A371E04C F9EE5EAB A8466FDF EBC16772 5B6F420C 300D0609
  2A864886 F70D0101 05050003 81810082 D8940AF2 10AEA426 96789F16 746B63AB
  C1D4B3AF 2743E3A9 52C4CD9A 736755E9 F66B3E47 A5DCB92E 8137D59D 6B3168E1
  46B671FA CDBCF1C9 A7D0A78D C09C038C 8A048938 6F8A9A30 1B4C488E 5496F714
  F5FB6D88 79A4AE2C 89EE86AE 399A2CC6 A1980BBC 5F86375B 98A7C61B 5690F0A2
  B05906CB 00C3CDF5 EE37CD7B 90EFA1
       quit
ip source-route
ip dhcp excluded-address 192.168.99.1 192.168.99.20
ip dhcp pool edi-client-dhcp
network 192.168.99.0 255.255.255.0
default-router 192.168.99.1
dns-server *.*.69.2 *.*.63.2
domain-name EDI-CLIENT.ADSL
lease 8
ip cef
ip name-server *.*.69.2
ip name-server *.*.63.2
no ipv6 cef
password encryption aes
license udi pid CISCO887VA-K9 sn FCZ1648C23R
username * privilege 15 password *
controller VDSL 0
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
class-map type inspect match-any CCP_PPTP
match class-map SDM_GRE
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
match protocol pptp
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
class class-default
  drop
policy-map type inspect ccp-pol-outToIn
class type inspect CCP_PPTP
  pass
class class-default
  drop log
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-zone-To-in-zone source out-zone destination in-zone
service-policy type inspect ccp-pol-outToIn
zone-pair security ccp-zp-out-self source out-zone destination self
interface Ethernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly in
hold-queue 100 out
interface ATM0
ip address *.*.99.30 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description $FW_INSIDE$
ip address 192.168.99.1 255.255.255.0
ip access-group 101 in
ip nat inside
zone-member security in-zone
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname *@hg43.btclick.com
ppp chap password *
ppp pap sent-username *@hg43.btclick.com password *
ppp ipcp dns request
ppp ipcp wins accept
ppp ipcp mask request
ppp ipcp route default
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip route profile
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended SDM_GRE
remark CCP_ACL Category=1
permit gre any any
access-list 1 permit 192.168.99.0 0.0.0.255
access-list 2 remark Auto generated by SDM Management Access feature
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 192.168.99.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark Auto generated by SDM Management Access feature
access-list 101 remark CCP_ACL Category=1
access-list 101 permit tcp 192.168.99.0 0.0.0.255 host 192.168.99.1 eq 22
access-list 101 permit tcp 192.168.99.0 0.0.0.255 host 192.168.99.1 eq 443
access-list 101 permit tcp 192.168.99.0 0.0.0.255 host 192.168.99.1 eq cmd
access-list 101 deny   tcp any host 192.168.99.1 eq telnet
access-list 101 deny   tcp any host 192.168.99.1 eq 22
access-list 101 deny   tcp any host 192.168.99.1 eq www
access-list 101 deny   tcp any host 192.168.99.1 eq 443
access-list 101 deny   tcp any host 192.168.99.1 eq cmd
access-list 101 deny   udp any host 192.168.99.1 eq snmp
access-list 101 permit ip any any
access-list 102 remark Auto generated by SDM Management Access feature
access-list 102 remark CCP_ACL Category=1
access-list 102 permit ip 192.168.99.0 0.0.0.255 any
line con 0
line aux 0
line vty 0 4
access-class 102 in
exec-timeout 120 0
password 7 11282A0A191B083F07382E332C213C341615300A19775554
login local
length 0
transport input ssh
end
1 ACCEPTED SOLUTION
Silver
You have added CCP_PPTP class to ccp-pol-outToIn, i. e. out-to-in direction, but I guess the guests initiate this traffic from inside to outside.
In addition, you've added the two ACL lines to ACL 100 which is used for invalid-src drop traffic. It should be added to SDM_GRE ACL instead.
Silver
Thanks Peter,
I will give that a go, just to confirm, what you are suggesting is the ACL should look like this? I think the SDM_GRE ACL was created by the firewall wizard. Does the IP access group SDM_GRE then need to be listed under the Dialer0 group Out?
permit gre any any
Silver
No, SDM_GRE is referenced in a class-map which is referenced by the zone-pair security policy. I guess it's not easy to find it in CCP GUI, I'm just referring to the object names in the CLI config.
Ok, I think I get that...so I have taken out the two entires in access-list 100 so this is all I have now.
Also go slightly confused about what you mentioned in regards to the CCP_PPTP class, but you are right, the guests will be going in to out so I think what you are trying to tell me is I will need to create a new service policy and associate this class with the ccp-zp-in-out source in-zone pair. Is that right. Sorry about this, really trying to get my head round the firewall on this, only just got it properly connecting to the net after about 4 weeks of trying.
I've got it working now, I made sure GRE and PPTP classes were on the in to out zone and it worked.
Thanks for pointing me in the right direction.
match protocol pptp
match protocol dns
match protocol ftp
match protocol icmp
match protocol imap
match protocol pop3
match protocol rtsp
match protocol smtp
match protocol tftp
match protocol tcp
match protocol udp
match protocol icmp
match protocol tcp
match protocol udp
match protocol h323
match protocol sip
match protocol http
match protocol pptp
match protocol dns
match protocol ftp
match protocol icmp
match protocol imap
match protocol pop3
match protocol rtsp
match protocol smtp
match protocol tftp
match protocol tcp
match protocol udp
match protocol icmp
match protocol tcp
match protocol udp
match protocol h323
match protocol sip
match protocol http
642
