08-06-2010 01:57 PM - edited 03-11-2019 11:22 AM
I want to allow a system in the DMZ (75) access to a
database server in a higher security (100) and also still allow the server in the DMZ access to the internet from inside.
From the inside out to the internet works fine unless I change the access rules.. is there an acl that I use for this or how do I do this. The ports are from internal systems 172.16.10.10(DMZ) to 172.16 20.10(NONDMZ) and need ports 1433,5151, and some in the 14000 range. Can anyone assist me?
Solved! Go to Solution.
08-06-2010 02:30 PM
Firstly, I assume your outside interface has a security level of 0 so both the DMZ and INSIDE interfaces will be able to go outside since their security levels are higher.
To allow the DMZ to talk to a host on the INSIDE, then you must create an access-group and and access-list for the DMZ network.
Let's assume that the DB is a mysql server running on 192.168.1.100 on port 3306 and you have interfaces with DMZ and INSIDE as names.
access-group DMZ_access_in in interface DMZ
access-list DMZ_access_in extended permit tcp any host 192.168.1.100 eq 3306
Of course, you can be more specific with your ACL by adding a host instead of the keyword any, i.e.
access-list DMZ_access_in extended permit tcp host 172.16.10.10 host 192.168.1.100 eq 3306
Hope this helps,
Conor
08-06-2010 02:30 PM
Hope this helps,
Conor
08-06-2010 03:26 PM
That should help nicly thanks
