Allowing Traffick Between vlans on ASA5505
I have a Cisco ASA5505 configured with 3 vlans outside = x.x.x.x \24, inside = 10.217.46.1 \ 27, and wifi = 10.217.46.33 \ 27. I have security plus liscense but i cant access anything in the inside if im on wifi or i cant access anything from wifi if im on inside cant even ping between vlans but access to the internet is working just fine on both sides any ideas.
Hello Robert,
What is the security level between interfaces? Would you mind sharing your configuration?
-Eddy Duran
they are both at 100
Super Bronze
The easiest way to solve this would naturally to see the configuration.
The main things that might affect on the firewall side are
  • Missing interface ACL
  • Missing some NAT configuration (depending on software level of the ASA)
  • The interface "security-level" are set to identical which would block traffic between these interfaces if you DONT have "same-security-traffic permit inter-interface"
You can also take the "packet-tracer" output if you want to test the firewall configurations/rules
packet-tracer input inside tcp
packet-tracer input wifi tcp
One common problen with ICMP through the firewall is missing ICMP Inspection
It can be added with
fixup protocol imcp
fixup protocol icmp error
Or alternatively by entering
policy-map global_policy
class inspection_default
  inspect icmp error
  inspect icmp
- Jouni
Super Bronze
You need to add "same-security-traffic permit inter-interface" atleast
- Jouni
152
