Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
AnyConnect users cannot reach inside network and ASA?
Here is the envirnoment
Firewall : ASA5510 9.1(2)
ASDM : 7.1
Firewall IP : 192.168.88.1
Office Inside network : 192.168.88.x
AnyConnect VPN : 172.16.89.x
Result #1:
Office user can
- access the Internet
- access to VPN User's computer
- access to ASA firewall
Result #2:
VPN user can
- access the inside network
- cannot ping/access inside network's computer
- cannot ping/access the ASA firewall
Anybody could help where should I need to check?
Attached with the ASA configuration
Thanks in advance
Sam
Everyone's tags (3)
2 ACCEPTED SOLUTIONS
VIP Purple
Re: AnyConnect users cannot reach inside network and ASA?
How do you test it?
For Ping you should add the ICMP-Inspection:
policy-map global_policy
class inspection_default
  inspect icmp
And what is the difference between
Result #2:
VPN user can
And I forgot to mention that the nat-exemption has to be inserted *above* the other nat-statements:
nat 1 (inside,outside) source ...
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Super Bronze
For management through the VPN you should probably use the "inside" interface IP address by inserting the following command
management-access inside
Then you should be able to connect to the "inside" IP address from VPN provided that the other configurations allow it.
- Jouni
VIP Purple
there is no nat-exemption for your vpn:
nat (inside,outside) source static INSIDE-88 INSIDE-88 destination static VPN-89 VPN-89 no-proxy-arp route-lookup description NAT-Exempt for VPN
NAT added, but still the same result
VIP Purple
How do you test it?
  inspect icmp
Result #2:
VPN user can
Thanks Karsten~ after the NAT has been moved to the above, VPN user can ping and access the inside network's computer now,
But the ASA firewall still cannot be accessed by VPN user.
For the ICMP-inspection, seems there is no big difference between turning it ON or OFF
Super Bronze
- Jouni
Thanks everybody!! all problems resolved !
289
