Anyway to add rulebase comments (at CLI not PDM) to 6.3 Pix?
Re 6.3 PIX
Cannot see a "Description" type command for this but want to add clarity to the rulebase - also we do not use a PDM to manage - just CLI - thanks
Gold
Re: Anyway to add rulebase comments (at CLI not PDM) to 6.3 Pix?
I you are talking about ACL desription you need to use "remark"
fe.
access-list 101 remark --access to outside--
M.
Hope that helps rate if it does
I don't have access to a test firewall until later tonight. However I happen to have an acl 100 that is about 25 lines long. Can you use the "remark" command in the specific line as the actual acl - or would I have to have a remark line preceding each and every one of the 25 constituent lines that comprise acl 100?
For example:
access-list 100 remark --allow tacacs--access-list 100 permit host 10.1.1.1 172.16.1.1 eq tacacs
access-list 100 remark --allow DNS--
access-list 100 permit host 10.9.1.1 172.16.1.1 eq domain
access-list 100 remark --allow other stuff--
access-list 100 permit host 10.9.1.1 192.168.1.1 eq otherstuff
and so on ??
Gold
I guess you can insert remark to specific line
witch command
access-list 100 line xxx remark ----
You will see lines witch command
show access-list 100
OK will test tonight and post reply - thanks for prompt help
yes all works fine
157
