07-09-2012 10:04 AM - edited 03-11-2019 04:28 PM
I am hoping someone can help me answer this question:
We currently have redundant FWSM's and are planning a migration to standalone ASA 5500 series firewalls. However, we have a complete VMWare environment and are looking at the Nexus 1000V. I understand the Nexus 1000V and VSG architecture and implementation, and I do understand that the ASA 1000V is designed for cloud environments. But I do have one question about the ASA 1000V.
Is it possible for an ASA 5500 series firewall to be replaced by an ASA 1000V? Basically, can an ASA 1000V be a sole firewall solution, or are ASA 5500's still needed?
Is there a datasheet anywhere that compares the ASA 1000V and ASA 5500 series?
Thanks for your help.
-Joe
Solved! Go to Solution.
07-09-2012 08:23 PM
Depending on what you are using the ASA5500 series for currently. If you are using the ASA5500 for remote access vpn and AnyConnect VPN, it will not be supported on the first release of the ASA1000V yet.
Here is the Q&A on ASA1000V that includes more information:
http://www.cisco.com/en/US/partner/prod/collateral/vpndevc/ps6032/ps6094/ps12233/qa_c67-688050.html
Hope that answers your question.
07-09-2012 08:23 PM
07-10-2012 04:08 AM
Thanks for your response Jennifer. However, the link you provided I do not have access to (I get a 403 forbidden warning).
So, the ASA1000V and ASA5500 are pretty much the same exact thing but the only thing missing from the first release of ASA1000V is VPN and AnyConnect capability, correct?
From what I am reading, it appears that ASA1000V has all functionalities of an ASA5500 except for VPN. I just want to make sure I am clear on that point.
07-10-2012 04:37 AM
Yes, you are correct.
Try this link, it should work for you:
http://www.cisco.com/en/US/customer/prod/collateral/vpndevc/ps6032/ps6094/ps12233/qa_c67-688050.html
07-10-2012 04:39 AM
Thank you Jennifer.
