Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5500 and DHCP Problem
Hello everybody.
I am facing a problem.
DHCP is active on the INSIDE interface.
However i get the following log messages:
UDP request discarded from 192.168.1.254/67 to INSIDE:192.168.1.1/67
dhcpd address 192.168.1.2-192.168.1.249 INSIDE
dhcpd dns 8.8.8.8 8.8.4.4 interface INSIDE
dhcpd lease 36000 interface INSIDE
dhcpd enable INSIDE
The dhcpd state shows inside as active.
I really dont get, why it doesnt get an offer back.
Super Bronze
Shouldn't the source address for the request be "0.0.0.0" and not an actual IP address from the same subnet?
Or is some network device forwarding initial DHCP messages to the ASA?
There shouldnt be many things that could be wrong with the DHCP on ASA. Either you use DHCP for hosts that are connected to the ASAs interface running the DHCP or you are using dhcprelay on the ASA to relay the DHCP messages to an actual server.
- Jouni
Community Member
Hi Jouni,
basically the requests commning from a wireless controller. thats why its not 0.0.0.0.
If i connect a host directly to the ASA i get a DHCP. I would like to use the ASA as DHCP over the wireless controller.
Do you have any logs while the issue happens, I mean we can see on that monitor tool that you were dropping packets but we will need to see what the logs say to determine why this happens.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Community Member
Hi Julio,
the only log message i see (that is related to this), is the one i posted:
hmm it got to be something else, I mean that log does not show that the Interface went down it only shows that a UDP packets was not allowed to traverse the ASA due to the Accelerated Security Path ( ASP algorithm)
Julio
Julio Carvajal
Silver
Re: ASA 5500 and DHCP Problem
I am having the same issue, did you find any solution for this...
Below is my config
dhcpd dns 208.67.222.123 208.67.220.123
dhcpd lease 43200
dhcpd ping_timeout 20
dhcpd option 3 ip 172.16.8.1
dhcpd address 172.16.8.40-172.16.8.167 guest
dhcpd enable guest
and the logs..
%ASA-7-710005: UDP request discarded from 172.16.8.201/67 to guest:172.16.8.1/67
172.16.8.201 is the wireless controller and 172.16.8.1 is the Firewall Guest interface
Siddhartha
Siddhartha
Silver
found the issue.
ASA s don't support Unicast DHCP requests, thts why its discarding the proxied DHCP requests from the wireless controller.
work around- Disable DHCP proxy on the controller ( its a global setting not a per WLAN setting)
https://supportforums.cisco.com/thread/2178369
Siddhartha
Siddhartha
2293
