ASA 5500X Etherchannel With Mixed Copper and Fibre Ports Fail
ASA5500x - 9.1x
Unable to configure an etherchannel using a mixture of the on board UTP and an SFP interface from the ASA-IC-6GE-SFP-A module (which does support etherchannels unlike the SSM-4GE= ). Both are configured to run 1Gbps. Can anyone confirm that you cannot mix the two.
Cisco documentation advices "All interfaces in the channel group must be the same type and speed. The first interface added to the channel group determines the correct type and speed. ". However it does not elaborate on the definition of "type".
Error shown "WARNING: GigabitEthernet0/0 is not compatible with GigabitEthernet1/2 and will be suspended (speed of GigabitEthernet0/0 is 1000 Mbps, GigabitEthernet1/2 is 1000 Mbps)".
Hall of Fame Super Silver
An Etherchannel with port
An Etherchannel with port members across the base unit and an ASA-IC-6GE-SFP-A expansion is a supported configuration.
You don't perhaps have a nameif on one of the members you are trying to add do you? That will cause the creation to fail.
There are no nameif
There are no nameif configurations on either port, the firewall is new and had no previous configuration. The etherchannel is partially formed but one or the other will is suspended (depends on which on was added second). Have done "clear config interface" on both interfaces and port-channels, still no joy. The downstreams are a pair of Cisco NX5Ks, with a VPC.
interface GigabitEthernet0/0
channel-group 10 mode active
no nameif
no security-level
no ip address
interface GigabitEthernet1/2
no nameif
no security-level
no ip address
interface Port-channel10
speed 1000
duplex full
nameif INSIDE security-level 100
no ip address
Group  Port-channel  Protocol  Span-cluster  Ports
10     Po10(U)           LACP          No     Gi0/0(s)   Gi1/2(P)
Check your Nexus to make sure
Check your Nexus to make sure the ports your ASA interfaces are connected to are configured properly and that the VPC is healthy and allowing the expected VLAN. If the ASA doesn't see them as going to the "same" downstream device that will cause the failure as well.
"show vpc brief" (on the Nexus) should show it for you.
Hello Alex,
Hello Alex,
We have this problem to, what was the solution ??
BR
Ernst
248
