Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5505 7.2(2) using ASDM 5.2(2) - Need to throttle bandwidth
Hello all,
I have an ASA 5505 7.2(2) using ASDM 5.2(2) and I need to fix two items:
1) Throttle bandwidth down to 1MB on the traffic going in/out of my FTP server on the inside using NAT
2) Re-enable the ability to access my FTP server using the url ftp://ftp2.xxxx.com.  This used to work, but somewhere in configuring the ASA I lost the ability to use the outside url, and can only access the FTP using the inside IP address.
Any help is greatly appreciated.
Thanks in advance.
Steven
Everyone's tags (1)
1. Refer to below links..
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008084de0c.shtml
https://supportforums.cisco.com/thread/2040620
2. Post the configs from ASA. It may relates to 'Nat' issue.
hth
MS
Community Member
Re: ASA 5505 7.2(2) using ASDM 5.2(2) - Need to throttle bandwid
I will look into #1 above.
running config is attached as requested.
thanks
can you try by removing 'insect ftp' under policy-map global_policy?
Thx
MS
Community Member
Removed.
Saved to memory - no change.
Steven
I guess you need to allow ftp-data as well..
access-list out_in extended permit tcp any host x.x.91.243 eq ftp-data
If it does not resolve the issue..
1. make sure your requests hitting the firewall outside interface
2. Check from Server end that FW passing traffic to the server and server responding back (you can us etherreal on server to capture the traffic)
Thx
MS
Community Member
Sorry, still not working.
I can get to the ftp site from the outside (home system via remote) so the requests are getting through the firewall correctly - just not bouncing back to the server from the inside.
1898
