ASA 5505 - allow traffic between inside interfaces
Hi All - Cisco ASA Novice here...   I have a question that I'm guessing is pretty straightforward.  I trying to allow traffic between 2 inside interfaces with the same security level.  VLAN1 and VLAN15.  The are on different physical ports on the ASA.  I tried to configure this through the GUI Web interface and checked ' enable traffic between two or more interfaces with the same security levels'.  With this ASA version, I do not need NAT to allow this, correct?  What am I missing?
ASA Version 8.2(1)
hostname ciscoasa
enable password UMrZyv1DTPLXGFch encrypted
passwd UMrZyv1DTPLXGFch encrypted
names
name XX.YY.163.39 EDI_XX.YY.163.39
name XX.YY.163.38 EDI2_XX.YY.163.38
name 10.66.91.135 UMASS_10.66.91.135 description UMASS VPN
name 172.16.16.236 EDI2_172.16.16.236 description Polaris EDI2
name 172.16.16.235 EDI_172.16.16.235 description Polaris EDI
name 192.168.25.17 ImagingInst_192.168.25.17 description ImagingInstitute
name 192.168.25.21 ImagingInst_192.168.25.21 description ImagingInstitute
name 192.168.25.22 ImagingInst_192.168.25.22 description ImagingInstitute
name 192.168.25.8 ImagingInst_192.168.25.8 description ImagingInstitute
name 10.88.0.4 UMASS_10.88.0.4 description UMASS VPN
name 10.88.8.80 UMASS_10.88.8.80 description UMASS VPN
name 172.16.16.231 Utility_172.16.16.231 description Testing
name 172.16.16.241 MonitorInt_172.16.16.241 description MonitorInt
name AA.BB.136.26 Monitor_AA.BB.136.26 description Monitor
name AA.BB.154.135 Monitor_AA.BB.154.135 description Monitor
name XX.YY.163.40 Utility_XX.YY.163.40 description Used for  monitoring, and may be used for other
name XX.BB.188.130 Monitor_AA.BB.188.130 description MonitorTest
name 172.16.16.232 Gateway_172.16.16.232
name XX.YY.163.41 Gateway_XX.YY.163.41
interface Vlan1
nameif inside
security-level 100
ip address 172.16.16.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address XX.YY.163.36 255.255.255.240
interface Vlan5
shutdown
nameif dmz
security-level 50
no ip address
interface Vlan15
nameif MCBackendTraffic
security-level 100
ip address 172.22.1.220 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 15
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone GMT 0
same-security-traffic permit inter-interface
object-group network ImagingInstGroup
network-object host ImagingInst_192.168.25.17
network-object host ImagingInst_192.168.25.21
network-object host ImagingInst_192.168.25.22
network-object host ImagingInst_192.168.25.8
object-group service EDI2_Ports tcp
port-object eq https
port-object eq ssh
object-group service EDI_Ports tcp
port-object eq ftp
port-object eq ftp-data
object-group network DM_INLINE_NETWORK_1
network-object host UMASS_10.66.91.135
network-object host UMASS_10.88.0.4
network-object host UMASS_10.88.8.80
object-group network DM_INLINE_NETWORK_2
network-object host Monitor_XX.YY.136.26
network-object host Monitor_XX.YY.154.135
network-object host Monitor_XX.YY.188.130
object-group service Monitor_Ports
service-object tcp-udp range 48000 48020
service-object tcp eq ssh
service-object udp eq snmp
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
access-list outside_1_cryptomap extended permit ip 172.16.16.0 255.255.255.0 10.242.55.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 172.16.16.0 255.255.255.0 10.242.55.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip host EDI2_172.16.16.236 host UMASS_10.66.91.135
access-list inside_nat0_outbound extended permit ip host EDI2_172.16.16.236 object-group ImagingInstGroup
access-list inside_nat0_outbound extended permit ip 172.16.16.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
access-list inside_nat0_outbound extended permit ip any 172.16.16.96 255.255.255.240
access-list outside_access_in extended permit tcp any host EDI2_XX.YY.163.38 object-group EDI2_Ports
access-list outside_access_in extended permit tcp any host EDI_XX.YY.163.39 object-group EDI_Ports
access-list outside_access_in extended permit object-group Monitor_Ports object-group DM_INLINE_NETWORK_2 host Utility_XX.YY.163.40
access-list outside_access_in extended permit tcp any host Gateway_XX.YY.163.41 object-group DM_INLINE_TCP_1
access-list outside_2_cryptomap extended permit ip 172.16.16.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
access-list outside_3_cryptomap extended permit ip 172.16.16.0 255.255.255.0 object-group ImagingInstGroup
access-list throttle_edi_servers extended permit ip host EDI2_XX.YY.163.38 any
access-list throttle_edi_servers extended permit ip any host EDI2_XX.YY.163.38
access-list throttle_edi_servers extended permit ip host EDI_XX.YY.163.39 any
access-list throttle_edi_servers extended permit ip any host EDI_XX.YY.163.39
access-list RemoteAccessVPN_splitTunnelAcl standard permit 172.16.16.0 255.255.255.0
pager lines 24
logging enable
logging timestamp
logging asdm warnings
logging mail errors
logging from-address noreply@utility..com
logging recipient-address aa@bb.com level errors
logging host inside Utility_172.16.16.231
mtu inside 1500
mtu outside 1500
mtu dmz 1500
mtu MCBackendTraffic 1500
ip local pool VPNPool 172.16.16.101-172.16.16.111 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) EDI_XX.YY.163.39 EDI_172.16.16.235 netmask 255.255.255.255
static (inside,outside) EDI2_XX.YY.163.38 EDI2_172.16.16.236 netmask 255.255.255.255
static (inside,outside) Utility_XX.YY.163.40 MonitorInt_172.16.16.241 netmask 255.255.255.255
static (inside,outside) Gateway_XX.YY.163.41 Gateway_172.16.16.232 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 XX.YY.163.33 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 172.16.16.0 255.255.255.0 inside
http 10.242.55.0 255.255.255.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer AA.CC.125.146
crypto map outside_map 1 set transform-set ESP-3DES-MD5
crypto map outside_map 2 match address outside_2_cryptomap
crypto map outside_map 2 set peer AA.CC.139.26
crypto map outside_map 2 set transform-set ESP-3DES-SHA
crypto map outside_map 3 match address outside_3_cryptomap
crypto map outside_map 3 set peer AA.CC.56.227
crypto map outside_map 3 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 1
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
telnet 172.16.16.0 255.255.255.0 inside
telnet 10.242.55.0 255.255.255.0 outside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns XX.YY.136.155 XX.YY.136.100
dhcpd auto_config outside
dhcpd address 172.16.16.5-172.16.16.100 inside
dhcpd dns XX.YY.136.155 XX.YY.136.100 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec svc
group-policy RemoteAccessVPN internal
group-policy RemoteAccessVPN attributes
dns-server value 172.16.16.230
split-tunnel-policy tunnelspecified
split-tunnel-network-list value RemoteAccessVPN_splitTunnelAcl
default-domain value .com
username remote password HP6P1nlQDIJY7Y8G encrypted privilege 0
username remote attributes
vpn-group-policy RemoteAccessVPN
tunnel-group AA.CC.125.146 type ipsec-l2l
tunnel-group AA.CC.125.146 ipsec-attributes
pre-shared-key *
tunnel-group AA.CC.139.26 type ipsec-l2l
tunnel-group AA.CC.139.26 ipsec-attributes
pre-shared-key *
tunnel-group AA.CC.56.227 type ipsec-l2l
tunnel-group AA.CC.56.227 ipsec-attributes
pre-shared-key *
tunnel-group RemoteAccessVPN type remote-access
tunnel-group RemoteAccessVPN general-attributes
address-pool VPNPool
default-group-policy RemoteAccessVPN
tunnel-group RemoteAccessVPN ipsec-attributes
pre-shared-key *
class-map throttle-me
match access-list throttle_edi_servers
policy-map throttle-policy
class throttle-me
  police output 524000 4000
  police input 524000 4000
service-policy throttle-policy interface outside
smtp-server 172.16.16.231
prompt hostname context
Cryptochecksum:884757d08c2dab5220a40758f543f8fb
: end
Everyone's tags (1)
1 REPLY
Would this work?
access-list nonat extended permit ip 172.22.1.0 255.255.0.0 172.16.16.0 255.255.255.0
access-list nonat extended permit ip 172.16.16.0 255.255.255.0 172.22.1.0 255.255.0.0
nat (inside) 0 access-list nonat
nat (MCBackendTraffic) 0 access-list nonat
2583
