Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5505 and 5520 netflow
Good morning support,
We had some ASA 5505 and 5520 and would like to send flow statistics to a netflow collector. is it possible with models 5505 and 5520 and with Version 8.0?
Thanks and regards
Fran
Everyone's tags (3)
Re: ASA 5505 and 5520 netflow
AFAIK only the 5580 has netflow capabilities in ver 8.2
No other ASA platform supports netflow at this time.
http://newsroom.cisco.com/dlls/2008/prod_012208.html
HTH>
Hi all,
I think I found interesting information about the topic:
ASA version 8.2 software supports NetFlow export across all ASA models,
The implementation used on the ASA platforms is NetFlow v9 which is defined
by
RFC3954. The feature was introduced in ASA 8.2.1/ASDM 6.2.1.
I hope it will be helpfull
Best regards
Fran
ASA version 8.2 for any ASA model supports Netflow.
Here is a sample config for it http://supportforums.cisco.com/docs/DOC-6113
I hope it is clear now.
PK
Here is how to configure the ASA:
http://www.lovemytool.com/blog/2009/09/plixer.html
We have been getting a few calls with questions on the uniqueness of the NetFlows exported by the Cisco ASA. Check out this PDF:
http://www.plixer.com/files/netflow-on-the-asa-11-18-09.pdf
Make sure you are running 8.2.1.  Use Scrutinizer for NetFlow Analysis.
Good luck,
Jake
6426
