Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5505 and PPPoE
I have 5 statically assigned IP addresses from my ISP and I use a Netopia 3364 DSL modem for PPPoE authentication. This box is able to split out the public IPs to downstream firewalls, routers, etc, but when I connect my ASA 5505 to it and assign it one of the static IPs, I am unable to connect to the Internet. I am, however, able to see the web page for the Netopia and I am able to get the configuration to work with a Linksys router (in fact, 2 of them; each assigned a different public IP). I did not configure PPPoE on the ASA 5505 but simply assigned its outside interface to one of the public IPs, as I did with the Linksys. Any ideas?
Green
Re: ASA 5505 and PPPoE
Did you enter a default route on the ASA?
I presume you set a default route using the setroute option, but this is not available if you use the "ip address [ip_address [mask]]" command. When I try to use the "ip address [ip_address [mask]] pppoe [setroute]" command, I get an error.
Green
But you're not using pppoe on the ASA right?
route outside 0.0.0.0 0.0.0.0
Here's the running config output. I'm not sure if it's entirely correct. I got the next ip address from the Netpoia web page.
ASA Version 7.2(2)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address xxx.xxx.xxx.74 255.255.255.248
interface Vlan3
nameif dmz
security-level 50
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 3
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
dns domain-lookup outside
dns domain-lookup inside
dns domain-lookup dmz
dns server-group DefaultDNS
name-server yyy.yyy.yya.1
name-server yyy.yyy.yyb..1
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_access_in extended permit tcp any xxx.xxx.xxx.72 255.255.255.248 eq www
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
global (dmz) 1 192.168.1.10-192.168.1.125 netmask 255.255.255.0
nat (inside) 1 192.168.1.0 255.255.255.0
static (dmz,outside) xxx.xxx.xxx.72 192.168.1.100 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 192.0.2.100 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.100-192.168.1.129 inside
dhcpd dns yyy.yyy.yya.1 yyy.yyy.yyb.1 interface inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:####
: end
Green
Your default route would be to an ip address on the same subnet as your outside interface...xxx.xxx.xxx.74 255.255.255.248.
192.0.2.100 is most likely not correct. What is the address on the netopia?
Okay, I changed it to xxx.xxx.xxx.78, which is its assigned address and still no go.
Well, I did a reset to factory defaults and configured NAT within the address range given to me by the ISP; after a few minutes, it worked, so I guess the problem was in address translation across the interfaces.
828
作成コンテンツを作成するには してください
