Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5505 and WLAN controller 2200 DHCP issue
I am having issues with the ASA 5505 allowing the controller and AP1130 getting DHCP address. DHCP works for all other clients but not thr controller or the APs. I can connect wirelessly with a static IP.
1 REPLY
Re: ASA 5505 and WLAN controller 2200 DHCP issue
My running config on the ASA 5505.
ASA Version 7.2(3)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
clock timezone MST -7
clock summer-time MDT recurring
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit udp any range bootps bootpc any range bootps bootpc
tcp-map ExceedMSS
exceed-mss allow
queue-limit 250
reserved-bits clear
no ttl-evasion-protection
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp deny any outside
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group inside_access_in in interface inside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client update dns server both
dhcpd lease 115000
dhcpd address 192.168.1.10-192.168.1.130 inside
dhcpd dns 192.168.0.1 interface inside
dhcpd enable inside
class-map global-class
match any
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
description ExceedMSS
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
class global-class
set connection advanced-options ExceedMSS
inspect ipsec-pass-thru
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
416
