Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5505 base liscense - 10 inside hosts?
Hi all
I would like to know what exactly means the restriction aplied with base license that comes with ASA 5505 regarding inside hosts.
I've readed that every host connecting from inside to outside (internet access and so son) counts as one, but all host behind my ASA (arround 25) can properly access to the internet.
Thank you
Miquel
1 ACCEPTED SOLUTION
Re: ASA 5505 base liscense - 10 inside hosts?
This restriction means that only 10 SIMULTANEOUS IP addresses (hosts) can connect through the firewall at a specific time. Check the "show local-host" this will tell you the current connections in use.
1 REPLY
207
