ASA 5505 config help
I will like to configure inside/outside interfaces on the ASA 5505 as you see on the attached file can you help.
I configure so far
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 192.168.10.1 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
and get dhcp/static to work when I connect directly to the ASA but did not see any when I connect it thru mini-hub or switch. I appriciate your help
1 REPLY
Re: ASA 5505 config help
If communication works fine when directly connected, it's not an ASA issue. Other than ethernet settings, there's nothing else you can configure for that particular issue
111
