Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5505 - dual wan: wan1 for vpn l2l-wan2 for everything else
Hi to all.
My goal is to use dual wan (with 2 different ISP):
I would use:
wan1 for all: web, mail, ecc
wan2 only for a vpn l2l connection with HQ (voip, intranet).
Obviously the wans have to work at the same time.
It's possible with asa 5505? (without a router).
Do yuo know some tutorial for that?
Thank you.
Everyone's tags (8)
1 REPLY
Hello Paolo,
It will work as you will specify 2 different destinations on the routing table of the ASA.
It's going to be as simple as that,
Set the 2 interface, configured the proper NAT for those 2 interfaces, set the routes and finally the crypto map on the Wan2.
Julio
Remember to rate all the helpful posts, that is as important as a thanks.
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
805
